Old 3rd November 2014, 06:19 AM
mannyo mannyo is offline
Sounds exactly like mine when a coilpack failed, should just be a case of get a new one (they are not expensive) and replace. They seem to fail suddenly, which is what happened to me.
VCDS should be reporting a cylinder misfire in 01, engine and this would be the pack to replace.
The lambda errors could be cause by unburnt fuel being dumped on the probe.
Manny
Past
Old 3rd November 2014, 06:30 AM
SilverS8 SilverS8 is offline
Thanks alot guys.
Anyone know if the coilpack is the same as on 1.8T? Have a new spare for my wife's A6z
Jan
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 3rd November 2014, 08:43 AM
As far as i can see, Vcds does not report any missfire, even with the suspected coil disconnected it wont show any errors other then the Lambda's mentioned earlier, Isn't that strange??
Played around and got these.
Address 01: Engine (4D0 907 558 J)
10:30:44
-13.3 % O2 Sens Bank1 +/-10%(>2% flct)
-25.0 % O2 Sens Bank2 +/-10%(>2% flct)
-3.1 % Lambda
Total misfires 0-5
1.872 V Cylinder 1 Volts
1.872 V Cylinder 2 Volts
2.340 V Cylinder 3 Volts
1.872 V Cylinder 4 Volts
2.691 V Cylinder 5 Volts
2.574 V Cylinder 6 Volts
2.574 V Cylinder 7 Volts
2.457 V Cylinder 8 Volts
Anyone read some interesting from this?
2000 Silver S8
Old 3rd November 2014, 02:14 PM
The coils are different on the D3, not sure with the D2. The difference is mostly the length to the spark plug, so if they are the same length and the connector is the same it should work.
Manny
Past
Old 3rd November 2014, 04:26 PM
Update:
Changed location of 2 of the coilpacks to make sure the one was dead.
Well, now it all works for some reason and i have ordered 2 new coils since its just a matter of minutes before it dies i guess..
Tok me a good 10 min drive to clear the exhaust for umburned gas.. I can assure that the amount of smoke has to be some kinda record.
Jan
2000 Silver S8
Old 3rd November 2014, 06:01 PM
My son had a failing coilpack on his S4 a while back, caused all sorts of oddness.
By the time he got it into the garage for rectification 2 had definitely gone.
They replaced all 8 on a precautionary basis.
