Old 10th November 2014, 09:40 AM
The nearest tree to where I park is an Oak. No acorns have been found anywhere in the car. There is a silver birch in the area, but it's between 2 back gardens at least 50 yards away and my house is in between it and the car.
As the sun is out I'm letting a combination of car greenhouse effect and solar sunroof ventilation do the drying work for now. I'll have a look at the drains a bit later.
Old 10th November 2014, 12:48 PM
Interesting. I took the nearside drain out - easier to get at and as my drive has a slight slope it's the "downhill" one.
A good 700ml of slightly-coloured water came out of the condenser tray.
I then took the orange drain pipe indoors to inspect. It looked ok at first glance, but was definitely blocked.
The exit tip was clear, I'd trimmed it back a bit previously so the slots were open about 3mm anyway. I think the blockage was in the "horizontal" pipe section, it blew out very easily.
I collected the bits. It was plant debris, all quite small only 1mm or 2mm along/across. About half was unidentifiable black woody/seedy material and the rest was those blasted seeds!
It obviously settles in the tubes as water dribbles through and slowly builds up until blocked. I can't think of any obvious way to stop that so I guess it will just have to be a regular maintenance job.
Still need to work out how the excess water/debris arrives there though.
