Old 11th November 2014, 09:48 AM
located in the "easy access" position behind the dash trim (just below the instruments "check" button) it's working fine.
And was spot on when I got in the car after the clocks went back the other day.
Old 16th December 2014, 01:01 AM
Daz 70 Daz 70 is offline
Default how bazzare
Having fitted the Radio Module to the Back of the dash panel (D2 Pre FL) I simply left it and thought I would try and sort it later...
For some reason having no fiddled with the car at all for the last couple of months... and when I got in it Sunday night was display the time (+1 plus) and also the ant symbol... whaooo.... great....
HOWEVER I cannot adjust the clock to mins one hour.... well not with the buttons unless there is a trick?
So unless it can be edited by logging in.... but then If I have to do this everytime..... I probably worse off than I was before... ;-/
Any help or suggestions....
Thanks
Daz
Old 16th December 2014, 08:01 AM
Not sure how you do it PF, is it not in the drivers manual?
On FL it's the DIS menu controlled via the button/knob in the cupholder tray near the handbrake (never did get that!), which obviously isn't there PF.
If it's via VCDS, so be it, you only have to do it once after all and it's set.
Where exactly is your receiver?
Old 16th December 2014, 01:29 PM
>> and also the and symbol... whaooo.... great....
This is great. Does it mean that on PF you don't have to fiddle with adaptation channel?
I can't help with shifting the clock one hour though. On FL it is done via the same clock menu. You can only add/subtract hours in the radio controlled clock mode in the clock menu. You can't change minutes or date in this mode. Only hours. I'm sure the + and the - buttons on the cluster will do the same. Perhaps you need to long press them... I never tried though...
You're probably the first one in the UK who has fitted it to the PF A8.
You need to blaze the trail to understand how to shift it one hour.
Good luck
Old 16th December 2014, 01:40 PM
There is no coding for radio controlled clock mentioned in ElsaWin and nothing about adjusting radio controlled clock in users manual I guess you have already tried the usual way of holding down both HR and MIN buttons pressed down at the same time for 2- 3 seconds like you do when normally adjusting clock?
Old 28th March 2015, 01:59 PM
OK, put mine in today and placed the receiver in the same spot as HPsauce. But I can't seem to get the hang of the VCDS coding (first time I've tried doing anything other than a scan. Where do I find 'channel 19'?
Old 28th March 2015, 02:02 PM
From here: http://www.vagcom.org/modifications/...trolled-clock/
(I think that's in instruments)
VAGCOM / VCDS changes
go to module 17, adaption 10, channel 19:
xxxx0 = disabled radio controlled clock
xxxx1 = enabled radio controlled clock
so change the last number to 1.
