I have some new data.
Using a 110Ah Bosch S5 battery which is in a very poor condition, I got the following results. At start: VCDS oil temperature before connecting battery to pan heater: 8C Battery voltage under load: 11.7V Current: 9.0A Watts: 105.3W after 30 minutes VCDS oil temperature: 12C Battery voltage: 11.0V Current: 8.5A Watts: 93.5W Conclusion, it seems that it takes 7.5 minutes to heat the oil by 1C with input average wattage of around 100W |
