Old 19th November 2014, 07:27 AM
Great stuff, when you get the voltage step-down unit, check it doesn't cause interference to the radios when there is a load on it as I have had trouble with this from 2 or 3 DC-DC converters in my A8. I had
  • LED drivers : DAB drop out
  • Griffin USB cigar socket charger : weak DAB and FM hiss
  • Cigar to media layer : FM hiss and no TMC for sat nav
Old 19th November 2014, 07:33 AM
Thanks for the heads up mate
Old 19th November 2014, 07:42 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
The unit is so small, the connections are Micro usb for power and its supplied with a cigar lighter adaptor to USB.
A/V cables are 3.5mm jack to RCA leads, it comes with both male and female so either way you should be fine.
I currently have it powered from the power socket in the luggage compartment,
I have a this on order so I can connect it properly in behind the trim panel.
Nice one.
That's a cracking little power unit.
never knew you could get them.
Thanks
[center]
06 3.0TDI Quattro:
Options:
Old 19th November 2014, 08:45 AM
Nice work Del
Yesterday I was looking more in-depth at resistive touch screen panels. Maybe you also found this in your research, Link
Not sure if this can be used with the Kivic One.
I'm guessing that you link the phone to Kivic with WiFi Direct?
Matt
Old 19th November 2014, 09:24 AM
Nice work Del
The Kivic One is purely a wireless link to the phone, for touch screen connection to the phone another system is required.
The route I was going to take is using Mimicsx2, it basically connects to the phone via bluetooth, and allows you to control it remotely.
Have a look at this video and you will see better than I can explain.
Old 19th November 2014, 09:51 AM
Damn, that's good!
Matt
Old 10th December 2014, 11:34 AM
Hi All,
Del, did you receive the power supply?
Did it work OK?
Before SWMBO treated me to an AMI I was experimenting with a radio transmitter but found that quite a few of the cigar lighter power supplies could cause RFI(Radio Frequency Interference).
I have ordered one of these PSUs to try it.
Old 10th December 2014, 03:01 PM
I did receive it, but I have yet to fit and try it to see if it creates any issues
Old 14th January 2015, 05:55 PM
£128 on ebay - uk shipped now.
Waiting for mine to be delivered.
Thanks for being the pioneer Delboy.
Old 15th January 2015, 02:25 PM
Look forward to your thoughts and experiences
