D3 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
OK, deep breath lol
The standard 20" wheel fitment for a D3 is a 9Jx20 ET46. From memory with a 275/35R20 tyre Looking at the wheels you've mentioned: the fronts should give 10mm additional clearance on the inside, but be more inset at the outside due to the narrower wheel (compared to a factory 20) so spacers should sort that. Rolling radius is 2% out from stock The rears will be 12mm closer on the inside and stick out 14mm less on the outside. Again spacers can sort. Have a look here: http://www.willtheyfit.com/index.php...et2=45#content and try substituting the spec of your existing wheels rather than the factory 20s to give a better idea of where you might be able to get them out to. check the tyre rolling radius too - I think you're OK but with quattro it's very important to be very close to the same rolling radius front to back.
