Old 20th December 2014, 12:24 PM
Sir WIll Sir WIll is offline
Yes I should of added it moves fine, sprung loaded of course but I can operate it by hand no problems.
Old 20th December 2014, 01:09 PM
You know what at $89 + $35 for postage the aftermarket links are just too expensive for what they are.
I am going to buy some thread and ball sockets and make some myself
I will update on progress when they have arrived.
Old 20th December 2014, 01:24 PM
Being just a little pedantic, Sir Will, and begging your pardon for being so, but this is not a secondary air injection system issue with which this thread started (although the original poster did stray onto the variable manifold system problem that his investigations highlighted - possibly because the vacuum required to control the variable intake manifold and the secondary air system is provided by the same two vacuum reservoirs). I am sure that there is a considerable thread on the subject of VIM/actuators/arms elsewhere.
Erm, I'll get my coat....
By the way, I think that you are right about the cost of the links. Look forward to seeing your results
Old 20th December 2014, 01:30 PM
Yeah I know, I have hijacked things a little
Old 20th December 2014, 04:00 PM
On my previous S8 I used stainless steel ones from RS components.
Next time round I'm going to use aluminium ones from ebay, easier to tap threads deeper and file down if needed.
http://forum.a8parts.co.uk/showpost....5&postcount=12
http://www.ebay.co.uk/itm/L800-M8-8m...item3cc0090445
and for the other end use a male track rod end, then you actually wont need to do any tapping of the female one, just cut/file down the male one if its too long.
http://www.ebay.co.uk/itm/Track-Rod-...item4ad8cb72f4
and yes, its nothing to do with secondary air injection
Old 20th December 2014, 04:15 PM
Still nothing to do with secondary air injection......
But it's interesting as I have ordered the parts already but was on the the same thought process as you and bought RC car track rod ends!
I remember having to buy them for my Tamiya Lunchbox all those years ago!
Old 21st December 2014, 09:20 PM
Good stuff
post a pic when you install them it would be interesting to see how it looks.
