Old 23rd December 2014, 09:42 PM
darrenjoe90's Avatar
I would suggest that you take both the SWB W12 and the V10 S8 for a good test drive. I would say that one is no better than the other and it would be down to personal preference.
Just avoid LWB W12.
Audi S8 Phantom Black
Old 23rd December 2014, 09:58 PM
Just avoid LWB W12.
This is all good advice.
I have driven them both extensively, and I personally prefer the look, spec and power delivery of the S8.
On paper the cars look very similar. Behind the wheel they both drive very differently. Only a test drive will help you decide which is right.
The LWB W12 usually has more kit, but this doesn't necessarily make it a good buy. SWB W12s when new numbered less than 100 iirc. Of these, only a handful got kitted out with top end specs, despite a large number of advertisers thinking they're fully loaded.
The one on the top banner of this forum is probably the highest spec you're likely to come across, and probably one of the best maintained, but sadly not for sale....
Old 24th December 2014, 12:07 PM
Having driven the W12, it's quick, but you don't know you're going quickly until you look at the speedo or out the side window. The levels of refinement in that engine and geabox combo are amazing.
If you want something geared towards spirited driving, then the S8 is that beast.
Or.. if you want something to smack you in the back of the head off the line with enough torque to tear up tarmac, then a remapped 4.2TDi
Old 25th December 2014, 08:06 PM
Very true. I've said before the 4.2 TDi is the best overall engine for the a8, giving reliability, economy and once past the brief turbo lag, some pretty pokey performance.
It's a big heavy block though so shares the front handling traits of the w12, but really bloody quick in a straight line and probably the ultimate Audi autobahn stormer....
Old 11th January 2015, 09:06 AM
A8 Doc A8 Doc is offline
The V10 S8, which has almost 400 ft lb of torque, being described as down on torque... Your loosing the plot
Yes sadly I am! It was my issue with the V10 and no turbos. It goes well but just you get bored too quickly..... I always wanted the RS6 V10 but never found one I liked and felt the interior was a come down after the A8.
So these two make almost enough torque each to keep me quiet
