Aux or AV 1 or 2 sadly dose not work. I have 3 different cameras off the net they all work perfect with the tv indoors but will not work in the car what so ever i think the frequency that it uses is different. I never did get to the bottom of it .. but i did conclude it must be oem or kufatec jobbie to work. I didnt mind the idea of manually changing to AV. Ment i could use it in moving traffic to see who is behind me better
Hi Guy, you may have the same problem I had with the wireless streaming box.
For some reason the video input craps out, for unknown reasons but if you have a video input live while the av1 or two is selected then open the settings menu and select pal/secam or whatever it says and the video feed will start working again. Its a tad annoying and TBH if you had to do all that faff to get a reverse picture up i think you would quickly tire of it. As an alternative to the xcar link how about this http://car-solutions.com/en/car-vide...en-support.php
Del ![]() Last edited by Delboy; 29th December 2014 at 08:18 AM. |
Del ![]() |
Ray, did you buy this? If retrofitting to an early D3 you'll also have to fit a newer Control Unit (4E0919283) as you'll have A or B installed. Revision C or higher is needed for a reverse camera. Only found one on ebay. http://www.ebay.co.uk/itm/Audi-A8-S8...-/331407316804
I never thought to ask but does your car have a tv tuner if not then I beleive you will need to add the fbas connector to it in order to integrate the rvc module or fit one that has the connector but that will require cp removal at a dealer.
Why would the parking aid need replacing Matt? Just curious
Del ![]() |
Hummm... I can't actually give an answer. It was something at the back of my mind having read a thread on Quattroworld. I'll see if I can find it.
This is my assumption
4E0919283A - 8 sensors, no graphical support 4E0919283B - 8 sensors, no graphical support 4E0919283C - 8 sensors, graphical support, rear view camera support 4E0919283D - 8 sensors, graphical support, rear view camera support
