Old 31st December 2014, 07:27 PM
Default Bi-xenon headlight dismantling?
Hi all
Does anyone know if the bi-xenon headlights can be easily stripped down, either by removing the glass or taking the internals out the back?
I bought some led side light bulbs but they're too big to go in through the hole in the back with the reflector in place inside the light unit. Should fit fine if I can put them in from the front, or possibly if I can open up the reflector a tiny bit. I'm assuming it's doable as I think you can buy replacement internal reflectors for the bi-xenons?
