Old 7th January 2015, 09:32 AM
I remember someone talking about a SMS activated relay to start the heater.
http://www.quantek.co.uk/GSM%20Remote%20Control.html
May be a cheaper alternative to the remote.
Mmmm all this heater talk has me thinking if it would be worth it on the S8
Old 7th January 2015, 09:42 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
It is worth it.
Group buy?
[center]
06 3.0TDI Quattro:
Options:
Old 7th January 2015, 09:56 AM
http://www.ebay.co.uk/itm/261633010631
I Think this is the pump, with the 90˚ inlet/outlet.
Old 7th January 2015, 10:06 AM
ScottD3's Avatar
Looks right.
Different plug but that's not really an issue.
[center]
06 3.0TDI Quattro:
Options:
Old 7th January 2015, 10:38 AM
You can get the 20mm coolant hose coupler from an aquatic/pond supplier and use the Audi Spring clips.
Old 19th January 2015, 07:53 AM
ScottD3's Avatar
I was working on a Range Rover over the weekend and noticed that the Aux heater was the same as ours and it comes with the recirculating pump that we want/need.
Its a 57 plate.
Not sure if it will help us in locating a pump.
[center]
06 3.0TDI Quattro:
Options:
Old 20th January 2015, 05:36 AM
Thats interesting i have all of that apart from the wabasto heater.. when i go in the shops i can leave it on a 15 min timer and the pump circulates the coolant keeping the car warm inside but only works if the engine is warm. The only pre heating i have is via the electric Quad zone again all done on times in the mmi menu ..
I wander if there was an electric version for cold climates that had a petrol model ?
