Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 13th January 2015, 02:37 PM
Two options - try to figure out whether the fault is the wiring to the boot mounted receiver, or the puck on the bootlid itself, or remove the sat nav unit and plug a GPS receiver into the back of the unit and stuff it somewhere behind the nav unit. If nothing else the latter rules out any headunit issues.
I gather water can sometimes get into the boot mounted puck, but more likely the wiring has got tired and is cracked somewhere around the boot lid
Old 13th January 2015, 02:48 PM
Duffy Duffy is offline
It's a D4 with a roof mounted aerial and accessing the aerial without collateral damage on the trim looks challenging.
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
2012 Porsche 981 3.4S PDK mid life crisis!
Old 13th January 2015, 03:16 PM
Spoke with my friendly Audi parts man, range wide problem with water penetration into roof mounted/external aerials rendering them useless. Spookily enough they easy to get from UK stock (he had 10 for A6's sitting on a shelf) £102 inc vat and postage so not an outrageous price.
1988 Audi 90 2.2E
2011 Mercedes E250
Old 13th January 2015, 03:45 PM
D'oh! I replied assuming it was a D2
Old 14th January 2015, 02:03 PM
If its such a common issue on a car that's only a year out of warranty its a shame they don't show a bit of goodwill and get it sorted for you....
Old 14th January 2015, 04:35 PM
You'd like to think so but I didn't get any vibe that that was on the table at all.....
I think if the dealer had seen the car previously I'd have been inclined to push it a bit.
1988 Audi 90 2.2E
2011 Mercedes E250
Old 20th January 2015, 01:28 PM
Did this today.
the back panel of the roof liner just pulls straight off and gives you limited access to the underside of the aerial. The aerial has 2 cables going into it and they have small tabs that pull downwards on the outer edge of the connectors and then they pull off. The aerial is held on by a T30 bolt and once you've undone that they aerial has 2 small black plastic tabs that need gently squeezed and it pops out.
The replacement comes unpainted, however the cover is held onto the base by 6 T6 bolts that once undone, allow the cover to come off and be swapped over.
Under the cover was soaking on my original aerial, I applied a thin coat of clear silicon to the cover edge before putting it onto the new aerial base.
£102 later and job done, sat nav now knows where it is.
Poor piece of design by Blaupunkt who make these aerials methinks
1988 Audi 90 2.2E
2011 Mercedes E250
