The rotation of the rear coupling will be the back lash in the diff along with any slack in the drive shafts etc connecting to the wheels. The majority of the slack will probably be from the diff
Del ![]() |
Thanks for the replies.
We've built a few rally car diffs and it doesn't look like back lash in the diff or shafts. There seems to be a 'two stage' rotation, with the first step taking up the slight 'slack' and then when more torque is applied there's a significant second rotation that leads up to the clunk. It's as if there's some type of 'cush drive' inside the diff, which seems extremely unlikely. When on the level I can change F/R direction and creep the car on tickover without causing the clunk, but as soon as any further torque is applied it takes up the movement and clunks. No we aren't 100% sure that it isn't a mounting and that's what I'd expected to find (propshaft centre bearing carrier was prime suspect), but the visible rotation in the rear coupling/joint really does point the finger. If I can't find any specific info I'll take the coupling off and investigate it, I was hoping to line up a replacement source or firm up a plan to use the one off the A4 beforehand tho. Any in depth technical info available for Audi transmissions? I don't mind buying some if it's available commercially at a sensible price, as we're also considering an S3/A3 Quattro rally car. Last edited by M3 Compact; 30th January 2015 at 02:04 PM. |
I haven't hears of this before on any forum, but when you are googling, don't forget to try searching the same symptoms with VW Phaeton and Bentley Continental.
Can only suggest you look at all the tech info in the "Tech Dump" sticky for D3s.
![]() http://forum.a8parts.co.uk/showthread.php?t=9347
2002 D2 S8 – Ming Blue, Valcona leather, Vavona wood insert, solar sunroof (to be fitted), Heated rear seats, extended leather pack, 18” Avus, ski hatch, Bose, auto dim rear view mirror, rear blind. Last edited by David's8; 30th January 2015 at 03:09 PM. Reason: Include thread link. |
![]() Which is in line with my findings, or lack of, and makes me further inclined to feel that our initial diagnosis seems unlikely. I've given up Googling now TBH; I've been searching for all Quattro models assuming that they'd probably use a similar style of rear coupling. |
