Old 30th January 2015, 07:34 PM
Default Window Regulator Issue?
I wonder if any of you have had electric window trouble?
Just popped out to buy some fish & chips and the passenger window would only open ~2-3" and stop. It didn't make any horrible nosies.
To close it I had to press the button 5 times and it goes up 1/2" each time.
Opening it again was a repeat of the above process.
It did this with the button on both doors.
It also did it after an ignition reset.
Does the A8 have a problem with window regulators/bowden cables like some other VAG models?
Old 30th January 2015, 08:29 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
I suspect they will have issues with the cables like other and I think my drivers window is on its way.
Theyu normally go slow or stop like that when they feel resistance. Its the anti pinch system kicking in I think.
Spray some grease on the runners and cable that you can get to should help.
[center]
06 3.0TDI Quattro:
Options:
Old 31st January 2015, 03:00 AM
Was it frosty? Wondering if the runners are swelled with ice crystals
Old 31st January 2015, 09:35 AM
Thanks for the replies.
Well it was frosty/icy in the morning but not so much in the evening.
Yes it was like the anti-pinch system was operating almost immediately.
My wife did try and open a window (but it was frozen shut) a couple of weeks ago when it snowed and I told her off and maybe the damage was done back then and we haven't tried to open it since.
I guess if I take the door panel off in this weather anything plastic will shatter into 3 pieces so will leave it until it's warmer and buy some clips etc...
Old 31st January 2015, 11:53 AM
Well would you believe it - it is normal today. Must be ice crystals or a lump of ice fell in as you say! *touch wood
