Can't fault them other than dragging the crap from the bottom of the sills and wheels all over the car.
I have yet to see a splash and dash that washes top down, uses grit guards etc.
Del ![]() |
The one here has a four stage process,
1 the car is sprayed with detergent, 2 the car is pressure washed, 3 the car is hand washed from the top down, 4 the car is hand dried after the door shuts are all cleaned. All done in different areas of the wash facility, and the cost is £7.
Sorry Mannyo, but my car would not go anywhere near these places. How do they manage? Answer: check out the chemicals they are using on your paintwork, you wouldn't use these yourself, and you can expect to start seeing the lacquer peeling off your alloys soon enough if you continue to use these places. Using sponges and leathers is bad enough, but I'll bet my mortgage that the ones they are using are the cheapest horrible rubbish and are never cleaned, in other words, they are dragging grit all over your paintwork. |
most of them use BRICK ACID on the wheels
i know a few people with knacked alloys from using these guys
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro |
