Old 1st February 2015, 04:15 PM
Norretal's Avatar
Norretal Norretal is offline
Hi Duffy, I can only comment on my own S8 but my gearbox is really smooth too, at 125,000 miles and rising. My gearbox oil was changed by IT if I remember rightly, maybe 5000 miles ago.
Audi TT - 2015 - Ultra
Old 3rd February 2015, 06:51 PM
Duffy Duffy is offline
Spent some time analysing this today, the box is slow when you are going into first after reverse has been used and its still switching over the cogs!
The D4 box is much quicker at changing and it's all down to my expectations, give the box time and its just fine.
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
2012 Porsche 981 3.4S PDK mid life crisis!
Old 6th February 2015, 06:36 AM
mannyo mannyo is offline
The change between R and D on my D3 is almost instant even first thing on a cold morning. Perhaps the fluid is low, as it warms up it expands which could explain why it improves once warm.
Manny
Past
Old 6th February 2015, 08:13 AM
I would concur. Possibly a past gear box fluid change that hasn't been done quite right.
The 6 speed boxes are generally very smooth, and i've never noticed a change in behaviour when warmed up.
I have seen a number of D2's with low fluid however that would have problems until they had warmed and the fluid had expanded.
The fluid is sensitive to temperature which is why it absolutely must be refilled at the guideline temp (around 40 degrees iirc) or you will get the wrong amount in....
Its a balancing act of running the engine to pump the fluids round, and not letting it get too hot.
I do shudder when folks take their car to an independent thats not done a gearbox flush before. You really want someone with a bit of experience imo
Old 6th February 2015, 09:06 AM
I was underneath the car on Tuesday (I took it into Kwik Fit for a precautionary oil change 10 litres Fuchs Titan Supersyn and a Meyle oil filter for £65) and the box is bone dry (the underside is fascinating actually very different to my D2 in a lot of detail) so if the fluid is low it's not a leak.
The car's only done 49K and it's a full main dealer history with the invoices here, there's no record of a fluid change ever having been done.
I'll get it into Mackies in Weegieland for a service I think. The car's a keeper so it's a worthwhile long term investment.
Thanks for the feedback
1988 Audi 90 2.2E
2011 Mercedes E250
Old 6th February 2015, 09:23 AM
They may want to do a software update and upgrade to LG8 (which is what went into my, not Ian's, D3).
Be prepared for a £600 bill
Old 6th February 2015, 10:30 AM
Is that the different oil designed to cope with worn hubs?
1988 Audi 90 2.2E
2011 Mercedes E250
Old 6th February 2015, 10:41 AM
Norretal's Avatar
I'll believe that if I see photos of it, which S8 did you buy?
Old 6th February 2015, 10:45 AM
Sorry?
You've lost me here........
1988 Audi 90 2.2E
2011 Mercedes E250
