Old 1st February 2015, 01:20 PM
Duffy Duffy is offline
Default MMI 2G/AMI very slow USB file load
Hi
I've just been through the whole firmware upgrade process with this and it's now on the latest firmware. However in general use I see that loading music (apple lossless/Mpeg4 files) from the USB stick (a 64gb stick recommended by someone else on here) it takes 20 seconds to load and/or buffer a song before playing.
Is this normal or perhaps caused by the size of the stick?
I can stick a Ipod or use the CD changer and it's immediate when playing.
I've got B and O so I'm keen to stick to uncompressed files as the difference in sound quality if very obvious with lower rate files.
Any thoughts?
Thanks!
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
Old 1st February 2015, 03:17 PM
I have always run a high bit rate for the reasons you state, but I've never tried lossless. I wouldn't have though it even supports it to be honest, but I guess it does.
The delay seems excessive, but depending on the brand / capabilities of the USB stick, that might be slowing things down. I don't even know how big a lossless track is in size these days.
I've never found skipping through MP3 tracks on the AMI any slower than the fractions of a second it takes to skip through an actual CD....
Old 1st February 2015, 03:41 PM
Lossless is circa 25-30mb per song, it sometimes plays and sometimes....
I use lossless on the ipod and they play perfectly but on the USB stick it's very slow and erratic.
The stick is a Lexar USB3 stick and should be fine, it's is being used by another D3 owner on here without reported issue.
It's a conundrum so it is!
1988 Audi 90 2.2E
2011 Mercedes E250
Old 1st February 2015, 03:42 PM
On a related note, I've just found this
http://www.oddgravity.de/app-opc.php
Which works brilliantly for creating playlists on the stick, it works at least!
1988 Audi 90 2.2E
2011 Mercedes E250
Old 1st February 2015, 04:17 PM
As a trial all I did was drag and drop a load of MP3 and WAV files from my desktop onto a 32 GB SD card. Then connected the card to the AMI via a USB card reader and it worked.
AMI displays everything alphabetically
in Artist order
in Album order
in Track order.
Hope that makes sense.
I have planned on doing some "proper" playlist loading but todate have not been motivated, 'cos it works
Old 1st February 2015, 05:23 PM
sarg sarg is offline
Probably of limited help, but my M3 has the exact same delays with a 64gb USB stick, but only for the first track, it plays okay once it gets going.
CD or iPhone plugged in is instantaneous
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 1st February 2015, 06:23 PM
Just remembered, I tried a 128 GB stick but that did not work.
Probably AMI software needs improving.
This leads me to think that it would struggle with a 64GB
Ray
Old 1st February 2015, 07:06 PM
I thought that there was something abut giving it a while for the system to catalogue the media drive/stick thing
Old 1st February 2015, 08:02 PM
If you go on the hidden green menu you can select the sync time for the AMI and after the update to 5570 it reverts to a slower time for some reason.
I changed mine back to 60ms i think and it works great again
64GB usb stick im using by the way
Old 1st February 2015, 08:34 PM
Ah a new thing I didn't know about, there's a lot of that at the moment!
Are these valid instructions?
https://therealtransporter.wordpress...le-and-access/
1988 Audi 90 2.2E
2011 Mercedes E250
