You can wedge something like a chunk of wood behind sprocket and rear of upper timing guard plate, then lightly tap the rear of the timing guard with a hammer to pop the sprocket off (it doesn't damage the guard provided you have filled the space between sprocket and guard on inside). Much easier than using pullers.
Thats brilliant thanks for the help.
2000 A8 D2 2.8 none Quattro ![]() 1990 Lada Niva Cossack Jacked 2008 Transit 140 www.tyresbarrow.co.uk |
