Old 27th February 2015, 01:36 AM
Botangs he iirc relates to d2 bodies.
But as mentioned the three main areas of ingress are sunroof, scuttle and air on drains.
Personally I have never done the aircon ones but the sunroof is quite easy to do.
Scuttle is a pain but has to be done, I do mine with a long slender hose attachment to a vax and suck out all the leaf debris then slowly pour hot water into scuttle area and you should see it pour out either side of transmission tunnel.
But from what you have said it sounds like it's either air con or scuttle drains
