D3 - Common Faults Quick links to all known common faults and their solutions |
What do you guys do with the phone in your cars? Is there a provider that gives you 2 sims for one number?
is there an upgrade you can do that allows bluetooth? or some kind of workaround |
I just use a Pay as you go SIM, and when in the car put a call divert on to the PAYG phone number. For the small usage I make using a PAYG sim works well, even if I do have to pay for the redirected leg of an incoming call.
Some new sim cards only work with version 5570 of the MMI software, you may get invalid SIM with most new cards until the MMI is upgraded.
You can also swap out your phone gubbins for a Bluetooth unit like some of us have.
Mines always been Bluetooth and connects as soon as I get in.
Del ![]() |
do you have any details of what you used for the upgrade?
Hi,
I had a Kufatec bluetooth module fitted in place of the original motorola module. It is located under the floor carpet in the front passenger footwell. Unit is a Kufatec Fiscon Pro and works just like the factory bluetooth available on later models of the D3. Not a cheap solution, unit is almost £400 ! One can also play music via bluetooth but sound quality is only fair. Much better than an aftermarket "parrot" type unit stuck on the dash though. Joe |
http://forum.a8parts.co.uk/showthread.php?t=908 covers the swap using the genuine Audi components.
The Mk9200 is good.. got one in SWMBOs X5.
Or there's the good old Dension unit as well.
