Old 4th March 2015, 09:01 AM
Default This may help also
area of particular attention worth looking into imo would be the
SWDL manuell - probably allows you to upload software, regardless of whether the disc is a
newer version
 SWDL ignore Region / VMC - probably allows you to upload software, regardless of the
locale driver.
Also if your doing updates to mmi please make sure that you have a 20amp min battery charger connected or have the engine running as a low voltage during update can create no end of problems
File Type: pdf audi-mmi-2g-high-hidden-menu-guide.pdf (307.6 KB, 749 views)
