Old 4th March 2015, 11:22 AM
Originally Posted by mattsimis View Post
The Sat Nav takes over the screen when Nav is pressed, its like running two Operating Systems. One view is standard Audi (and Radio etc) and the other is custom (Audi JP OEM) Nav stuff. They do it this way (I suspect) as Kanji cannot be read easily on the low res standard Nav input. Their implementation is direct to screen.
Yes, additionally you have these installed (in blue). I haven't found what module supplies the 2nd LVDS input, I would guess it's the Japanese nav unit. Search continues!
Edit: yes, the 2nd LVDS is from your Nav Unit.
Matt
Old 4th March 2015, 12:46 PM
mcs's Avatar
mcs mcs is offline
Bloody good info there.
I'm happy to photograph and document my MMI system for you if you need to compare and remove all the jap interface stuff.
Mike
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 4th March 2015, 12:53 PM
Default I wonder if the mmi screen is a better res
If as you say the different text requires a better display it may be possible that the screens better.
Could possibly rework the switch over device so an external trigger switched the display to a car pc type of unit mmmm need to do more digging.
But can't till get the Mac repaired
Old 4th March 2015, 01:05 PM
That's exactly what I thought Del. I did lookup all of the MMI screens and the part number only referred to PR codes with or without aluminium trim. Where a PR code of 8UV (High-level radio for China) or 8DZ (Radio "HIGH" Japan) was listed it only referred to a different adapter cable loom, probably the longer loom as it goes to that switching box.
Matt
