Old 13th March 2015, 04:17 AM
Hi Ray,
Glad to hear that it's back up and running again.
If it's the same place the flashed the original ecu then I would be inclined to give them nothing as its most likely them that fried the ecu by not having power supply connected during the flashing.
If anything I would be asking them to pay for the ecu that you bought.
Old 13th March 2015, 07:02 PM
As promised took her back this morning.
They plugged in their laptop and it read the ECU details. The resultant file was sent to the programmers. Modified file returned and they attempted to load it into the ECU. It failed to write, claimed loss of communication via the OBD port.
I left the car with them and called for it some four hours later. They had managed to do the reprogramming by opening the ECU and doing it on the bench. The car is now running properly . Let's see how long for.
The programming company people say there must be a problem with the OBD plug, and also said not to plug the diagnostic kit into the OBD in case it screws the ECU.
Anyone had a problem like this?
Old 13th March 2015, 07:27 PM
There are ecu's that require programming on the bench but I am surprised that yours needed it.
I think connecting vcds is not going to be a problem as the gateway is communicating with the ecu on your behalf as it's not a direct connection.
Old 15th March 2015, 11:04 AM
Set of at silly o'clock yesterday (Saturday) morning.
The car drove like an A8 all day.
M6/M5 south, cut off to Cirencester for a Little Chef breakfast,. Bummer, Little Chef is gone, now a petrol station and a sign pointing to a McDonalds.
Drove to Gloucester, did some shopping. Then continued along the A48 to Chepstow. Had lunch at the Beachley Ferry Inn. Then we drove back to Manchester via M4/M5/M6 for a family gathering dinner in The Trafford Centre, and eventually back home.
As said before the car was great!!!
Now the probs.
This morning I have plugged in VCDS and as expected, nearly five Zillion fault codes. Tried the "clear all codes" option with engine running. Switched off and restarted the car. Did another "Auto Scan" and after a quick perusal there seems no difference in faults reported.
SWMBO wants to go to Southport so bang goes another day to frivolous women things.
Just for fun here is my log:- (pick the bones out of this)
Sunday,15,March,2015,11:25:03:58733
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
www.Ross-Tech.com
VIN: WAUZZZ4E14N025504 License Plate: KR04 AUD
Mileage: 198530km-123360mi Repair Order: Test 03
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 1E 25 34 36 37 38
42 46 47 4F 52 53 56 57 61 62 67 72 76 77
VIN: WAUZZZ4E14N025504 Mileage: 198530km-123360miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Not registered 0001
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 401 H HW: 4E0 907 401 B
Component: 3.0L V6TDI G000AG 0050
Revision: --H01--- Serial number: AUX3Z0D3139689
Coding: 0011773
Shop #: WSC 66565 257 00032
VCID: 204FCCB5F3268E214EF-8075
7 Faults Found:
18278 - Transmission Mount Valve 1 (N262)
P1870 - 001 - Open Circuit - Intermittent
Freeze Frame:
RPM: 840 /min
Torque: 70.2 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.78 V
Bin. Bits: 00101100
Torque: 261.3 Nm
Temperature: 33.3°C
18057 - Powertrain Data Bus
P1649 - 001 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
RPM: 1155 /min
Torque: 0.0 Nm
Speed: 76.2 km/h
(no units): 11.0
Voltage: 14.52 V
(no units): 0.0
Bin. Bits: 00000000
Temperature: 84.6°C
29698 - Please Check Fault Codes in Comfort System Control Module (J393)
U1002 - 001 - - Intermittent
Freeze Frame:
RPM: 1155 /min
Torque: 0.0 Nm
Speed: 3.4 km/h
Duty Cycle: 1.0 %
Voltage: 14.44 V
Bin. Bits: 11001000
Torque: 257.4 Nm
Temperature: 84.6°C
16885 - Vehicle Speed Sensor
P0501 - 004 - Implausible Signal - Intermittent
Freeze Frame:
RPM: 1176 /min
Torque: 0.0 Nm
Speed: 3.4 km/h
Duty Cycle: 2.0 %
Voltage: 14.59 V
Bin. Bits: 11001000
Torque: 253.5 Nm
Bin. Bits: 00000000
17084 - MIL Request from Transm. Control Module (SAE) or Control Module Defective (VAG)
P0700 - 002 - - Intermittent
Freeze Frame:
RPM: 0 /min
Torque: -195.0 Nm
Speed: 0.0 km/h
Voltage: 11.86 V
(no units): 0.0
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
17610 - Fuel Injector for Cylinder 2 (N31)
P1202 - 001 - Electrical Malfunction - Intermittent
Freeze Frame:
RPM: 1638 /min
Torque: 444.6 Nm
Speed: 37.0 km/h
Inj. Quantity: 59.3 mg/str
Voltage: 14.14 V
Pressure: 1462.6 bar
Temperature: 20.7°C
Temperature: 52.2°C
17609 - Fuel Injector for Cylinder 1 (N30)
P1201 - 001 - Electrical Malfunction - Intermittent
Freeze Frame:
RPM: 1638 /min
Torque: 444.6 Nm
Speed: 37.0 km/h
Voltage: 14.14 V
Temperature: 20.7°C
Temperature: 52.2°C
Readiness: 0 1 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E0 910 156 F HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0100
Revision: 00000001 Serial number: 0018492
Coding: 0000001
Shop #: WSC 00000 000 00000
VCID: 2541DDA1EC046B093D9-8070
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
Component: ESP 5.7 allrad H44 0500
Coding: 0008357
Shop #: WSC 00196 000 00000
VCID: 224BC6BDFD2A9C3158B-8077
6 Faults Found:
00003 - Control Module
014 - Defective - Intermittent
014 - Defective
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D3139689
Coding: 0264192
Shop #: WSC 02311 785 00200
VCID: 58BFA455EBF606E176F-800D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H08 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3670112
Shop #: WSC 02313 785 00200
VCID: 2345C3B9E230953953D-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300DE047535272
Coding: 0000002
Shop #: WSC 00196 210 83196
VCID: 3A7B1EDD75BAF4F160B-806F
Subsystem 1 - Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
Subsystem 2 - Serial number: 322DP047506758
Subsystem 3 - Serial number: 7420.04.040000000000010056˙
Subsystem 4 - Serial number: 010056˙
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0300
Revision: 00000025 Serial number: 00000000042459
Coding: 1067009
VCID: 1B35FB59DA40ADF99BD-804E
1 Fault Found:
01858 - Air Outlet Sensor; Right Center (G348)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 4
Reset counter: 202
Mileage: 197100 km
Time Indication: 0
Date: 2015.02.21
Time: 05:49:43
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
Component: ILM Fahrer H12 0190
Coding: 0101104
VCID: 2F6D3F89BEF82159C75-807A
Subsystem 1 - Part No: 4E2 910 113 B
Component: Wischer WWS D3 H50 0420
Coding: 00000019
Shop #: WSC 02313
1 Fault Found:
02071 - Local Databus
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 5
Reset counter: 199
Mileage: 197588 km
Time Indication: 0
Date: 2015.02.22
Time: 11:17:56
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBD1036835
VCID: 1C37F845DF4EAAC1927-8049
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
VCID: 63C583B9A2B0D53913D-8036
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112041
VCID: 65C19DA1AC84AB09FD9-8030
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 AX
Component: KOMBIINSTR. VDO H54 0090
Revision: D21 Serial number: AUDID3F7000065
Coding: 0000403
Shop #: WSC 00196 067 57207
VCID: 5CB7B8459FCEEAC1527-8009
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Status: 00000011
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 168806 km
Time Indication: 0
Date: 2013.02.08
Time: 07:16:42
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 HW: 4E0 815 069 D
Component: Heizgeraet H06 0300
Revision: 0000000G Serial number: 00000009001484
VCID: 59B9A15190FC1FE9491-800C
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 16003043270643
Coding: FCFE5BDE2B7504
Shop #: WSC 00196 210 60652
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 169
Mileage: 198539 km
Time Indication: 0
Date: 2015.03.15
Time: 11:21:35
Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H20 0850
Revision: 00000000
Coding: 010000
VCID: 2B552B994AE05D79EBD-807E
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0264192
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H08 0060
Coding: 3670114
2 Faults Found:
01877 - Belt Height Adjustment Button (E333); Down
003 - Mechanical Failure
Freeze Frame:
Fault Status: 01100011
Fault Priority: 4
Fault Frequency: 4
Reset counter: 169
Mileage: 197804 km
Time Indication: 0
Date: 2015.03.07
Time: 08:23:50
01876 - Belt Height Adjustment Button (E333); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 169
Mileage: 197804 km
Time Indication: 0
Date: 2015.03.07
Time: 08:23:50
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
Revision: 00000000 Serial number: 353DJ047514344
VCID: 3B751BD97A80CDF97BD-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000409300093
Coding: 0035968
VCID: 1D31F541C454A3C9659-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: Türsteuer.FS BRM007 0110
Coding: 0028462
VCID: 5EB3B24D89D2F8D13C3-800B
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H04 0040
Revision: 00400004 Serial number: W040404210211
Coding: 0004345
VCID: 275DD7A9960879190F5-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H03 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000001459
Coding: 0000013
VCID: 2A5B2E9D851A447110B-807F
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000038976
Coding: 0010001
VCID: 1E33F24DC952B8D17C3-804B
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: Türsteuer.BF BRM007 0110
Coding: 0028462
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
1 Fault Found:
02596 - Rear Brake Pads Worn
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 122
Mileage: 196584 km
Time Indication: 0
Date: 2003.10.08
Time: 00:04:08
Freeze Frame:
Voltage: 11.90 V
Count: 61
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 304DV047586477
Coding: 0000001
VCID: 316939F1A8CC37A9D11-8064
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 12
Reset counter: 209
Mileage: 197033 km
Time Indication: 0
Date: 2015.02.20
Time: 10:11:12
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 G HW: 4E0 919 146
Component: TV analog TUNER H12 0300
Revision: 00000085 Serial number: 00000000002193
Coding: 0001003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0160
Revision: 00000000 Serial number: 00000000010676
VCID: 5DB1B54184D4E3C9259-8008
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 301008802E
Coding: 303030393135313035414B56413033303130303838303245
Shop #: WSC 73430 210 01865
5 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 2
Reset counter: 201
Mileage: 197806 km
Time Indication: 0
Date: 2015.03.06
Time: 16:41:15
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 6
Reset counter: 255
Mileage: 197806 km
Time Indication: 0
Date: 2015.03.06
Time: 18:38:11
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 12
Reset counter: 255
Mileage: 197806 km
Time Indication: 0
Date: 2015.03.06
Time: 18:38:21
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 12
Reset counter: 255
Mileage: 197806 km
Time Indication: 0
Date: 2015.03.06
Time: 18:38:31
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 197806 km
Time Indication: 0
Date: 2015.03.06
Time: 18:38:41
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028462
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H45 0630
Revision: 00000000 Serial number: 00000404010011
Shop #: WSC 12336 024 394758
VCID: 36630AED41A21091843-8063
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028462
2 Faults Found:
01482 - Motors for Central Locking
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 207
Mileage: 198480 km
Time Indication: 0
Date: 2015.03.14
Time: 17:27:38
02115 - Locking Unit for Central Locking
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 207
Mileage: 198480 km
Time Indication: 0
Date: 2015.03.14
Time: 21:56:40
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H12 0020
Revision: --.--.-- Serial number: 08730410704141
Coding: 0001008
VCID: 2149C9B1F82C8729411-8074
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0770
Revision: 00000006 Serial number: T2AUD31011HBH0
Coding: 0000004
End-------------------------(Elapsed Time: 03:10)--------------------------
Old 15th March 2015, 11:33 AM
I have had problems with a 2007 A8 not clearing all and had to do them individually - very annoying and have complained to VCDS about this. There is a check box which you need to select but i have still found it to be an issue.
Old 15th March 2015, 11:47 AM
Is that the little chef by the bp garage just off the A419 / Fosse Way that's closed Ray? I'd be amazed if it has, I went in there not that long ago (about a week) and as it is right next to a travel lodge it gets used for breakfast etc. are you thinking of the one that used to be about 2/3rds of the way towards Cirencester from Gloucester at what used to be another service station as that's been closed for years
Old 15th March 2015, 08:58 PM
It has been 40 years since I was in the area so looked it up on the useless tinternet. Little Chefs are closing pretty quickly and SWMBO is angry. It was on Burford Road, just of the A417. The address on the Little Chef web page was wrong. We had been to Birdlip, the boss had never been there, then via the A417 towards Swindon. Turned right towards Cirencester on the A429, garage on left.
Now with your advise I have found the correct location. Same junction, turn left away from Cirencester and at the first exit there is travelodge and Little Chef.
SWMBO has just beaten me up and said that I am a Banker. I should of gone into the garage and asked.
In future I will ask on THIS forum before I leave the house
Old 15th March 2015, 10:19 PM
That's the one Ray yes - so close but no cigar! Sorry about the domestic lol
Old 16th March 2015, 08:46 AM
Just had a big grin from my good lady.
Yippeee!! I am forgiven.
I'm due to visit Guy in the near future so will be giving another try at finding it.
Having a cuppa then taking her indoors for some shopping then we have to collect the basset from the kennels, he had a weekend there, spoilt rotten he is. On the way SWMBO has promised me a Little Chef breakfast at the Haydock site. It is on the A580 East Lancs Road and we see that one a few times a week so no let down.
Old 16th March 2015, 08:56 AM
On the subject of Little Chef, we randomly found one just North of Stoke last Autumn, I think it's called Talke, junction of A34 and A500 next to a Travelodge.
We were on our way from the Lake District to Leicester, avoiding the usual car park on the M6, and were in need of "sustenance".
Did the job.
Looking at maps, there seems to be another just a couple of miles away by the M6/A500 junction.
