Is the cigarette lighter feed in the boot a constant live or on with ignition?
I'd like to power a cool box, but not have it powered constantly so the battery flattens. Cheers. John.
2010 A8 SE Executive 4.2 FSI D4 2007 Mini Cooper S R56 2008 D3, gone, but not forgotten after 9 years and 90k. |
Cannot say for D3 but on A6 C5 it is permanently live. Easy enough to test though, just try it with ignition off either the actual lighter itself or something like phone charger and you will see.
Permanently live but should in theory turn off if battery gets low so should still start but your luck may vary.
Easy enough to find a switched live as well to control a relay.
Power socket left side of boot in a d3 is live all the time, but like snap says you ought to be able to find a ditched live somewhere in the boot and you could use that via a relay.
It's on my todo list as I still run the kivic one off the socket
Del ![]() Last edited by Delboy; 17th March 2015 at 08:22 AM. |
I would use one of these:-
http://www.ebay.co.uk/itm/Latching-r...tem1c4fb1 d89c Use a push button switch with a tell tale LED in it. The switch can be mounted wherever suits you, but you need to run a four core cable to the unit. Two cores for the switch operation and two for the LED. These only carry a very small signal current so the cable can be thin. You could supply the unit from an ignition switched circuit. Wired this way means that when ignition is switched on the relay stays in the OFF position. One push turns the relay ON, another push turns the relay OFF. If the relay is ON and you turn the ignition off the relay will also turn OFF, and will stay OFF when the ignition is turned on again. The tell tale LED in the push button lets you know what state the relay is in.
Ray at Wigan Pier 2014 A8L D4 4.0TFSI Gold (Sticker says "Beige") Can't leave you in a black smoke cloud anymore.. In progress, Nothing left to do. Gone 2004 A8 D3 3.0 TDI. Ebony Pearl Black (with little bits of other colours and glitter) Last edited by tc4332; 18th March 2015 at 08:52 AM. Reason: Edit the Link |
The Audi Fridge/coolbox when fitted is connected to power, i would suggest using the same source, as its obviosly the right place to put a fridge coolbox
here is the instructions for retrofitting the audi oem fridge http://www.audi-resource.com/retrocoolbox.php
A8 4.2TDI - Ice Silver, Comfort heated/cooled/massage Seats, Alcantara, Extended Leather pack, Ambient light pack, Solar roof, Night Vision, Lane change assist, Audi presense, Audi BrakeGuard, ACC Cruise, Blinds, Quad Air, AMI, Online services, Parking with rear Camera, Aluminium brushed inlays, Adaptive Zenons, High beam assist, Bose Sound, and more Gone but not forgotten: A8 D3 2005- AMI HDD, Audible Parking, TV, NAV, Bluetooth, Hybrid TV, Aftermarket headrest monitors, Rosstech VCDS / Vagcom |
Thanks all for the input. I know it's live when I've checked it, just wasn't sure if after x minutes it powered down.
I'll read that link when I get home. Thanks again.
Please oh please tell me where can I easily find one?
Audi A8 D3 2006 - 4.2 TDI in Phantom Black |
The only two I know of are a long way from the boot.
First in the roof electrics above the rear view mirror. Second is in the left hand fuse box. Open the passenger door and it is at the end of the dash. Forget which fuse but be careful, it takes a few seconds to come hot after ignition switch on and also stays hot for a short while after ignition switch off. The horrible thing fooled me for a while. I have put one of these in the fuse holder:- http://www.ebay.co.uk/itm/2305022319...%3AMEBIDX%3AIT Just make sure you put it in the correct way.
Ray at Wigan Pier 2014 A8L D4 4.0TFSI Gold (Sticker says "Beige") Can't leave you in a black smoke cloud anymore.. In progress, Nothing left to do. Gone 2004 A8 D3 3.0 TDI. Ebony Pearl Black (with little bits of other colours and glitter) Last edited by tc4332; 18th March 2015 at 08:49 AM. Reason: Edit to the link |
