Old 16th January 2010, 09:05 PM
builder22 builder22 is offline
Default Electric Window issue
Hey there,
I've not been on here too much lately so hello again.
I've noticed on two occasions recently on coming out of the house to the car that the rear passenger window is open. First time I thought I simply had forgotten to close it but for it to happen a second time the coincidence is too much.
So has anyone experienced these types of issues with the electric windows where they appear to have opened on their own accord?
I'm kinda worried about this for two reasons 1) obvious security issue (open window and all that) 2) when I discovered the window open the last time it had been raining and the back seat, carpet, etc got all wet. SO I would prefer to not have to deal with that again.
Should I remove the door card (any idea how to do this?) to check for any potential water damage or is this being overly paranoid?
Thanks in advance - Niall
Gone, but not forgotten...
2000 A8 4.2 Quattro – Green, S8 18’s, Xenons, PhatBox, and loads of other toys.
Old 18th January 2010, 09:20 AM
Hi guys,
Any thoughts on the above posting?
Niall
Old 18th January 2010, 09:34 AM
The doors are pretty watertight, I know of no A8 ever getting water ingress into there, and even if it did, the chances of it settling on the motor or switchgear is almost nil.
Instead, If it were my car I'd switch focus to the central locking pump in the boot. This is central convenicence module essentially, and has responsibility for alarm, central locking and windows.
If it were to get damp (say through a poorly fitted aerial on the wing for example) then you would be more likely to get electrical gremlins from that IMO.
Also note that the doors wouldnt be powered with the ignition off - another reason why I would look at the CLP first, as it is powered 24x7 and has the ability to move windows if it so wanted to...
HTH.
Old 18th January 2010, 06:13 PM
Ian - thanks as always.
Now for the silly questions - i can find a procedure for getting at the central locking module but is there any way of determining if indeed this is faulty? I can't imagine a visual inspection will tell me much.
Unfortunately i don't have a Vag Com but a local indy might have a reader that would help. Any thoughts or suggestions would be welcome.
Thanks again
Niall
Old 18th January 2010, 06:26 PM
Niall,
It's either VagCom or a physical inspection I'm afraid. You can code in/out a number of parameters with VagCom such as:
Single or 2 click on key fob for all doors open
Windows and Roof close with door locking using long press
doors lock above 10Kph
alarm beeps on lock
indicators flash on lock
and you can mix and match etc etc
