From here: http://www.vagcom.org/modifications/...trolled-clock/
(I think that's in instruments) VAGCOM / VCDS changes go to module 17, adaption 10, channel 19: xxxx0 = disabled radio controlled clock xxxx1 = enabled radio controlled clock so change the last number to 1.
Thanks, got it. How long before I should expect to see the little radio mast icon?
Tomorrow, if you're lucky. Should pick up summer time.
![]() You can fool it into checking earlier than the normal overnight process, but probably pointless, today of all days. ![]() (Someone worked out the logic, it's either earlier in this thread or linked to it. I fooled it just out of interest)
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 28th March 2015 at 02:56 PM. |
Set the clock to 2.50am and then lock and leave the car for an hour or 2 - should have sorted itself out by then
![]() When it's set the date will be correct but the time will be on mainland Europe so you then try setting the time manually and can correct the hour, but no other settings. Be quick about it and come tomorrow morning it will have reset for daylight saving time automatically ![]() The little mast symbol will always display assuming there's no failed time sync in normal use - mine works in the factory position even though it's always garaged when it's checking the time
Just to clarify, you set the hour offset (once it's got the radio symbol) using the menu control beside the handbrake.
Jim, you can find some substance on page 8 of this thread:
http://forum.a8parts.co.uk/showthread.php?t=6843&page=8
I'd rather drive on left |
Mine certainly has.
No icon in the display yet
Here's a little ditty I penned this morning, called 'Radio Clock Blues':
Well I woke up this morning (du Duh du du) And got into my car (du Duh du du) And then I noticed the time (du Duh du du) Had been set from afar (du Duh du du) There was a strange little symbol (du Duh du du) To the left of the time (du Duh du du) And although it is sad (du Duh du du) My face it did shine (du Duh du du) The whole thing's a mystery (du Duh du du) Why it took so long (du Duh du du) But it's working just fine now (du Duh du du) And that's the end of this song! (du Duh du du) Goodness knows why it took 4 days or so, but there you go. All I have to do now is get into the menu and set it t UK time (it's reading German time at the moment).
2002 Final Edition S8. Ebony black with Silver Grey leather and myrtle wood trim. Current mods: solar sun roof, 20mm rear spacers, 15 mm on front, red brembo callipers, 6k headlights, rear view camera, engine remap, alloy dash dial rings, alloy navi rings, tt/phaeton pedal upgrade, (and custom matching foot rest) dension ipod interface & parrot hands free kit (both fully hidden), av input, tv in motion switched thro' PF switch in blanking plug right of steering column, Audi 'quattro' sill covers, repositioned centre console switches, radio clock, .Planned mods: auto-dimming rear view mirror, dash cam (as steamship's), fit the ski hatch, refit philips drl's (or maybe not - nope, definitely not - horrible botch!). Last edited by The_Laird; 2nd April 2015 at 09:45 AM. |
At last.
![]() Must be that typically Scottish corrugated iron Faraday Cage you park it in.......
