They all are the 4.8mm terminal size that will fit in the fuse holder. But there's a different part number depending on the gauge of wire.
Oh I see. D'oh!
I've edited my post now to give it a bit more clarity.
Do you know where you'll pick up negative/ground for your RVC retrofit?
There is a pin on a connector in the boot lid for the camera, for the opener rubber handle I think. There is one on the back of the cigar lighter I used for the control module IIRC. I just temporary wired in the original audi camera and it worked straightaway. The 6 chinese ones didn't work at all in this application. Now I need to buy a new strip, handle etc with the camera aperture and have it painted
I'm gearing up for over a year now for a full AFS retrofit which includes rewiring headlights, adding xenon range module, fuses etc. And I was stuck until I found this chart which I have posted some times ago.
And this is what I have got at the minute, but today or tomorrow I am going to Audi again, but this time for some male terminals for my mates new audio upgrade inc. headunit. Believe or not, you probably will knowing Audi, but below you looking at just under £50 or even £60 worth of terminals, that is mainly coz Audi for some of them chage just over 50p for one. If you don't have an Audi or TPS close to you, then this guys are your answer, I found them two days ago while I was looking for a crimping tool for these terminals which I just found out are called JPT, Junior Power Times. Guys from Poland with terminals. Upgraded Priority International postage will cost you something like £4 in total, so if you buying a whole selection then it works out cheaper than Audi. http://www.ebay.co.uk/sch/m.html?_od...minal&_sacat=0 And this is the tool designed just for them terminals, with any other crimping tool it's just a pain http://www.ebay.co.uk/itm/1716253073...%3AMEBIDX%3AIT
Thanks Marcin, it's good that you're back
![]() I did have an ETKA pdf of all the pins, plugs and sockets somewhere on a computer of mine, but can't locate that file... So these web references came in very useful. http://www.passatplus.de/umbauteile/stecker/stecker.htm http://www.passatplus.de/umbauteile/...r/stecker2.htm http://www.passatplus.de/umbauteile/...r/stecker3.htm http://www.passatplus.de/umbauteile/...r/stecker4.htm http://www.passatplus.de/umbauteile/...r/stecker5.htm http://www.passatplus.de/umbauteile/...r/stecker6.htm
When the side panel trim left side of boot is off, where the cigar lighter point was there is a big earth point.
Thats what I used on mine. As for doing it in the boot lid, I have to disagree with Snap as its not a guaranteed earth as its a moving part and the earth resistance is likely to change.
Del ![]() |
