You need a conductance tester for the best battery test, not something private people will have. If you are an AA member, call them out and ask them to test it. Simply checking voltage wont tell the whole story
If, when I have done that,i havent found the issue I may have to get it to the repair shop. My guess is the G163 and G40 camshaft position sensors - tho' how they can fail doing nothing is beyond me. If it is the sensors would VCDS tell me IF I could get the engine started? The earlier scans just showed misfiring with a range of possible causes so how can a faulty sensor be detected?
There are Elsawin procedures for testing all the components. *removed* That was dumb of me, clearly G40 and G163 are different and not swappable. Coil packs you can test by swapping, if one cylinder is misfiring, swap coil packs with a 'good' cylinder and if misfire moves then its likely that coil pack.
I too find it hard to believe its any of these components which all worked when you left the car, still betting its a bad earth or corrosion somewhere supplying low voltage to components. Another random thought, is your ECU box dry inside? Attached is the Elsawin Hall sender testing procedure. Here is an interesting extract: Even without a signal from the Hall sensor, the engine will continue to run and can also be re started. ◆ When a fault is detected, the engine control unit produces one spark for each cylinder on every crankshaft revolution. ◆ The fact that the control unit is out of phase by one engine revolution does not have any noticeable effect on the injection system. If this happens, the fuel is injected "upstream" (before the closed inlet valve) instead of while the inlet valve is open. This has only a minor influence on the quality of the air/fuel mixture. Last edited by Goran; 31st March 2015 at 09:15 PM. |
Thanks for that, Goran.
![]() Ah well, its stopped raining now so I will go and do some further investigation......
Im not sure if this has been mentioned as i skimmed read the above, but you should be able to log misfires using measuring blocks in VCDS groups 10-19 under engine channel. Just drive around with the laptop on for a bit etc..
Unfortunately I cannot now start the car. I had hoped I could so i could identify the cause of the misfires which came up under the engine controller fault codes. What you have said would, i hoped, give the root cause e.g. CPS G40 sensor or whatever?
If you cant start it a CPS might be at fault agreed, but they dont often show a code. I had a situation with a 2008 A8 TDI and when hot mainly it wouldnt start and new CPS sorted it - took much head scratching and injector testing etc. Cant recall where they are on the S8 but they are usually easy to replace and not expensive and whilst i hate throwing parts at cars to fix a problem without diagnosing 1st, sometimes its a more economical use of time / money and the only option.
