Old 15th April 2015, 06:54 AM
kele kele is offline
I had a similar issue to that you describe on mine. The dealer fitted a mod (2 plastic bits each side of the interior lid). Could be same issue but not nessasarily. I will post some pictures at the weekend.... Although on mine there was no issue closing, I have to add.
2022 Mercedes EQC 400
2008 A8 3.0 Tdi sport, B&O
Old 16th April 2015, 12:53 AM
mcs's Avatar
mcs mcs is offline
Take the tools out of the bootlid and see what happens.
04 A8 - 4.2 Sport
Indigo Leather Sports Seats - Sports wheel - Sports Air Suspension
Auto Boot - Double Glazing - AMI - Solar roof
TV - Bose - Voice Control - TPMS - AFS- TINT
Power Blind, Fingerprint - Light package (in and out)
Retrofits:
OEM Auto headlights & rain sensing wipers
OEM Bluetooth phone
Bluetooth Audio Streaming
Reverse Camera
OEM Aluminium Package
Auto boot close using remote/door button
Old 16th April 2015, 09:40 AM
You can also try replacing the boot struts, easy to access and relatively cheap and will give it a bit more spring - often its enough to help a tired motor cope with age
Old 16th April 2015, 10:03 PM
centurion centurion is offline
i just did another scan today and got the following,
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601180371
Coding: 0004861
Shop #: WSC 02313 785 00200
VCID: 285F1E2B9B06C05EFC3-807D
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 3
Mileage: 228806 km
Time Indication: 0
Date: 2015.04.16
Time: 09:22:42
couple things - can the clutch [inside the motor mechanism] be replaced? If so, what is the correct part no. and could it be ordered?
In the meantime i will try the trick with violin resin and see how it goes
Old 17th April 2015, 10:35 AM
Only bodge it or replace the whole unit, they don't sell bits for it.
The other thing worth trying is make sure the hinges are lubed and free moving.
Also there is reports of the hinges getting bent/distorted so worth having a good look over it all before you go splashing cash on a replacement.
Old 17th April 2015, 01:28 PM
audifin audifin is offline
It would be very easy to replace the clutch, IF Audi sold the parts... but they don't. I've done a few of these and I'm yet to see a "tired" motor, it's always been the clutch slipping.
I fixed mine with violin rosin for about a year and 10k miles ago, still working fine. If it stops working I'll just do it again, it's a 20 minute job after you've done it once
Old 18th April 2015, 10:13 PM
need to find some time to take mine off for closer inspection but if violin rosin is the fix [albeit short-med term] i'll be doing Pavarotti all day long ...
something i've done today was to remove extra load [tools kit] from the boot, Oiled the same properly and it works much better now. What does occasionaly work though is opening from the remote or via driver's door switch.
More to follow...
