Old 17th April 2015, 10:42 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Not done anything exciting recently, just general maintenance like new bushes and tyres.
I did get time and the opportunity to polish the head lights and LED them.
Turning lights next.
ID:	10497   Click image for larger version
ID:	10498   Click image for larger version
ID:	10499   Click image for larger version
[center]
06 3.0TDI Quattro:
Options:
Old 18th April 2015, 10:25 PM
centurion centurion is offline
hi Scott,
i recently used some 'error FREE' 501's to replace std stock OSRAM's and i get the error on the dash... any suggestions how to remove that or did you experience the same with yours? Ta
Old 18th April 2015, 10:41 PM
ScottD3's Avatar
Talk to Trups at EM tuning.
He has a cabled that will solve your issue.
[center]
06 3.0TDI Quattro:
Options:
Old 19th April 2015, 10:10 AM
Somerandomguy's Avatar
You can also make your own loom for the front sidelights like this with holders from ebay for about £4
Old 19th April 2015, 11:43 AM
Is that in series or parallel?
Matt
Old 19th April 2015, 11:48 AM
They run in parallel, the loom plugs into the existing sidelight holder in place of the normal bulb to power two sidelights instead.
One of these is an LED which you then fit in the headlight, the other one you tuck out of the way - i also made a little cage to try to stop the old bulb from touching stuff that may melt
The holders i bought are these on ebay
http://www.ebay.co.uk/itm/181178128998
Though they seem to have sold out now
Old 19th April 2015, 12:09 PM
I left the old sidelight bulbs in their holders in mine - the small yellow glow of the sidelight bulbs is swamped by the 80w Cree LED DRL lol
