hi,
has anyone got any hints where EGR and MAF is/are on 4.2 TDI? and also what are the part no.'s for those? Cheers |
Del ![]() |
In the meantime to be absolutely sure it is indeed MAF, [stupid Q] if I was to disconnect them both could I start the car? or one would have to start it and then disconnect etc. also, any suggestion of where to source the part/s? Thanks. |
As far as I am aware the engines will run on a default map with them disconnected. Can't do any harm to try, you will no doubt have a mil light on and faults to clear after the fact but I'm sure that's the least of your concerns
Del ![]() |
![]() Q: is it worth changing the air filter [changed 6K ago] as I found lot of sand/small stones and all sort of rubbish in both housings (4.2 TDI engine)? |
