Old 23rd April 2015, 01:12 PM
oldnick oldnick is offline
the boot fuse box on my FL has the facility for 6 rows of fuses although all I have is [ from left to right ]
a jumbo fuse for ABS in row 1
a 20 amp fuse above a 25 amp fuse in row 3 , the upper fuse being the radio fuse referred to ....but don't you have a diagram inside the cover ?
incidentally , the radio aerial also seems to be fed through this fuse , mine appears to have the famous broken plastic cog ...the motor turns correctly but it doesn't move
a little research suggests that the radio amp is underneath the CD stack , no idea how I test for a fault if I take it out , my rear speakers don't work [ unless there is a control somewhere ] which could be connected ; the sound quality from all the front speakers is just fine
