Old 23rd January 2010, 05:02 PM
You have guessed right. Ben has pointed out that with the special tools the cams are locked in place the cam sprockets are loosened so they can rotate and after all the new parts are fitted and the cam belt tensioned. The crank is turned several times to make sure all the tension is taken up. Once this is achieved then it is brought to TDC and the cam sprockets are torqued up while being held in place. The cam locks are removed and all is in sync.
