Old 27th April 2015, 09:26 PM
oldnick oldnick is offline
Default rear speakers on A8 FL
my nokia rear parcel shelf speakers don't work
a bit of research suggests that this model with 2 connectors has a built in amp with a common 12v feed to the pair and the lack of this is the problem
it is also suggested that there may be an inline fuse for this feed
so how can I find this feed without taking the car apart ?
Old 27th April 2015, 09:31 PM
Nokia? Explain please.
What makes you think they don't work? Do the speakers in the rear doors work? Have you tested with the fader 100% rear?
Old 28th April 2015, 08:27 AM
A lot of D2 Speakers are branded Nokia... Not unusual.
The non-bose config has a line feed to the rear parcel shelf, and the speakers have a mini amp built in that amplifies the sound for the parcel shelf speakers, and then they feed the rear door speakers too.
The front speakers are driven direct from the head unit.
I've never head of the 12v dropping off before, but the whole audio loom is a separate loom with a single power connection in the rest of the car. I'd find it odd if the power was missing from there, but the rest of the ICE was working ok.
I'd start with a test meter on the speakers and see if 12V is getting to the parcel shelf.
Old 28th April 2015, 08:37 AM
Would that be via the 15/20A fuse #3A in the small panel above the battery which is labelled Radio/Loudspeaker?
Old 28th April 2015, 08:44 AM
Quite likely - The power feed for the audio kit comes from the back of the car and works its way forward, eventually connecting into the main loom on the left of the transmission tunnel at the front where it picks up canbus signals etc.
The multiblock connector should be visible if you remove the passenger side transmission tunnel cover iirc, but crumbs its been a long time since I worked on a D2....
Old 28th April 2015, 10:40 AM
thanks all , problem solved but don't know why !
yes , fuse 3A in the boot , which does all the sound system
and the fader is the explanation EXCEPT why do the back door speakers work fine with fader at 0 where I had it , and no detectable response from the parcel shelf speakers until the fader is turned to rear 10 at least ; THEN the rear door speakers are really blasting and the front speakers are quieter than ideal ?
just the design I suppose !
Old 28th April 2015, 12:22 PM
The parcel shelf speakers are just sub-woofers, the rear doors are the main rear speakers.
As noted elsewhere, use the bass control if the rear bass is inadequate - after adjusting the fader to suit.
Old 28th April 2015, 12:59 PM
thanks , will try that
