When I fitted mine I did the pin 4 link first.
It seemed to work correctly but I had only just obtained my VCDS and knew nothing. My first scan resulted in many faults but for this thread, here is the relevant report. For both of these I had "No Fault Found". 0E-Media Player 1 -- Status: Not registered 0001 1E-Media Player 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Revision: 00000501 Serial number: AUZ5ZBD1036835 Shop #: WSC 00000 000 00000 VCID: 1C37F845DF4EAAC1933-8049 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B552B994AE05D79EA9-807E No fault code found. ------------------------------------------------------------------------------- Somehow I eventually managed to lose the "Not Registered". Cannot remember how I managed it. And here are the current reports. 0E-Media Player 1 -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 Component: CD-Changer H43 0470 Revision: 00000501 Serial number: AUZ5ZBD1036835 Shop #: WSC 00000 000 00000 VCID: 1C37F845DF4EAAC1927-8049 No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels: 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B552B994AE05D79EBD-807E No fault code found. ------------------------------------------------------------------------------- OK none of this really helps but it might help someone to understand better. ![]()
The cable from the original MDI kit arrived today (sent from Germany), its also third party and missing the pin 4 loop.
I am therefore going to fit this cable set as its longer and much better quality. What I want to do therefore is remove one pin from the other one I am already using and place that in position 4. I'll split the wire sleeve and then solder the two together away from the connector block. The new cable has brown, orange and blue wires, I just need to establish which one is pin number 1 to create the loop. And also how to extract the wire from the connector block without the correct tool. Looking at the picture on page one, I have orange on top with brown on the bottom and blue is on its own to the left. I am also going to use the fibre loop from this kit because once again its longer than the one I am using currently.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 27th May 2015 at 11:45 AM. |
Hi Manny
There should be tiny numbers on the plug stating at least first and last pin in each row. You can make an extraction tool from a paper clip but fairly big/thick one so it's not too soft, straighten it and then u bend it so the two ends touching each other and there is a but if tension This us just a quick idea I've had after finishing reading your post, can't tell if it will work, but can't see why not if the clip is fairly thick. Good luck
Grrrr... what luck to receive an identically wired cable. At least it's an easy mod to add that extra pin.
Ironically, when I bought a loom for the DAB a 4 pin wired cable arrived - which I didn't need... ![]() Good luck ![]()
A year too late... but here's confirmation of Pin 4 in the Current Flow document.
Interesting, yours shows 2 discrete separate wires going to ground, where the one I was looking at last week showed literally a piggy back from pin 4 to 1.... Same net result, maybe I was looking a later model year....
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
I noticed that as well, but I had already marked up the 2003 edition. Post 09.2006 they did a piggy back to Pin 1. Wealth of information in that document
Right
Hopefully all sorted, found some spare time at work. Popped out to the car and removed one power cable, found I could not get the paperclip to extract the pin. So plan B was implemented, and after 15 mins using a scalpel and cutters, I had the required pin intact in my hand. Stripped a section of sleeving from the brown wire going to PIN 1 AMI on the new power loom, inserted the other PIN into 4 and soldered the two wires together. Applied some electrical tape and job done. I've plugged it all back in, AMI and CD Changer are both working. Not yet scanned the car to see if the faults I had are cleared, I'll do that later. Also need to deal with all that wiring, the fibre cables are so long its proving difficult to get everything back in without applying to much stress on the fibre. I do have a second fibre cable if one gets damaged though.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 27th May 2015 at 02:44 PM. |
Sounds to me like a job well done
![]() You can buy this conduit in split form to protect the optical fibre. http://www.ebay.co.uk/itm/321421416553
Of course I now have a spare good fibre loop, and no associated power loom because in effect I ended up destroying one of the connectors to get the wire to fix the other one.
