Old 21st May 2015, 03:32 PM
Default Is J519 control unit responsible for bulb warnings?
If so, could the firmware be modified so lower wattage lights can be used without issuing a bulb warning?
Matt
Old 21st May 2015, 04:03 PM
Is guess your probably right but how would you know where to start with something like that?
would it not be protected or compiled to prevent people like you messing with it
Old 22nd May 2015, 09:11 AM
You're probably correct Del. But I've gone ahead and bought a replacement unit to hack about with. I'm sure there are some STMicroelectronics eeproms on the board as I saw a modded Q7 J519 (see below pic). Hopefully the A8 will have similar and I can read them in my eeprom programmer.
Matt
Old 22nd May 2015, 10:48 AM
Interesting, so whats that unit been modified to do?
Old 22nd May 2015, 10:57 AM
On that Q7 unit they added some bridging wires because the owner was retrofitting V12 LED DRLS.
http://ludocar.free.fr/Audimodif/Aud..._partie_2.html
Matt
Old 22nd May 2015, 12:17 PM
So have you done any eeprom hacking before?
I would love to know the inner workings of some of these ecu's in the cars.
Been thinking of sniffing can data for a wee project
Old 22nd May 2015, 12:47 PM
No, never done any reverse engineering or eeprom hacking. Lot's of info on the web so will keep me out of trouble and annoying the wife
Take a look at CANBUS Triple if you're into sniffing CAN data traffic. I'm also interested in that. I have been trying to find a resource that has already analysed the VW/Audi data to identify what the codes mean. Otherwise you'll spend days deciphering them all. Do you know of a resource somewhere?
Matt
Old 23rd May 2015, 11:12 AM
Del, this is quite an interesting read - if a little heavy going over breakfast this morning.
http://www.ioactive.com/pdfs/IOActiv...trol_Units.pdf
Matt
Old 23rd May 2015, 12:13 PM
I had seen the CBT on my travels of the net for info, looks like a nice device.
Some interesting reading here too
http://forum.canb.us/discussion/9/vag-can-hacking
Old 23rd May 2015, 01:26 PM
It might be simpler to identify the current sensing circuit on the board and modify it. There's a good chance it may only be necessary to change one resistor.
I don't suppose there's a circuit diagram of that board available anywhere? If there's is, I should be able to identify the components you need to change.
