The saga continues, and I am now leaning towards a fueling issue.
This evening I tried to start the car several times on the driveway, but seconds after starting, it would die. This happened three times before the car would simply not start at all. I can hear the fuel pump prime however, so it doesn't seem to have failed completely. Interestingly, I now get the all-red highlighted PRNDS as soon as I switch the key to the first position, which I believe is indicative of limp mode? I'm assuming this will have thrown a code? |
The dash also seems to think that all the doors are open. Something seriously messed up.
When the pumps 'fail' as they do, they still prime, but don't deliver the required pressure, so the engine is starved.
It wouldn't account for any of the electrical gremlins you are seeing, and the chances of pump and electrical issue at the same time is virtually nil. I'd definitely be checking the connecting blocks for bad earth / positive connections as previously suggested. Even if they look good, take them off, clean them up and reseat. Failing that, I'd probably be looking for any signs of water ingress in the plastic plenum chamber under the bonnet at the back passenger side of the engine bay. It houses the gearbox and engine ECU, along with ESP/TC/ABS. Moisture in there can cause all sorts of 'fun'
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
I forgot to mention that on the second breakdown the car was stranded in a car park. Jumping did not start it, but a 5-litre can of fuel did seem to do the trick. The car does have have about 20-30 litres in it now though.
I'll have to do more investigation into the connections then. I took a look, but the negative and ground connections did look ok. Will clean and re-seat them. |
My bet is on the fuel issue. I had all the warning light issues you have had but that was due to leaving the car for 5 weeks so the battery was low attempting to start the car with the fuel supply issue drained the battery even further causing all manner of warnings to appear.
Yes, I'm wondering if I do have two problems now - the flat battery from attempting to start the car as you say, and the fuelling issue which is the real culprit.
If I stick my ear right over the pump cover when the ignition is turned to the first position, I should definitely be able to hear something, yes? Tried earlier and couldn't hear a thing there or behind the cap. |
So I've replaced the old battery, which has made starting much easier. I also filled the tank to the brim to test whether the problem only happened below 1/2 a tank as many people have experienced. I managed to go about 70 miles of mixed driving with nothing at all wrong yesterday, and then had a ten minute stretch of the car stalling, being difficult to start, and having a very lump idle. Not sure if it's worth noting that the revs won't drop if my foot is on the pedal, and I can prevent it from stalling by holding it.
My plan this weekend is to look at/reseat/change/clean the following: Fuel pump MAF Fuel filter Vacuum lines Throttle body Anything else I should be looking at? |
I think I might be close.
The car altogether will not start now, so I ran diagnostics. Got loads of short to ground codes for the injectors which from my research points to the fuel pump relay. Sure enough, when I took the casing off the relay and watched, it's not clicking shut, so the fuel pump is not coming on at all. Now if I push the connection shut, the fuel pump hums away happily, though the car will still not start - is this to be expected or is there something else going on? Relay is on its way either way. |
Is there power across the relay coil terminals? If not, the fault could be something further back that isn't energising.
I've not checked, no. Will look at that. Thought perhaps this is a crank sensor issue - the relay won't power up if there's no signal from that will it?
The other interesting thing is that I get the PRNDS light up when the car won't start, and there's an implausible signal code. If and when the car does start, that goes away and there's no transmission problem. Could the TCU be in any way affecting the fuel relay, or is the underlying electrical issue affecting both of them? |
