Old 4th June 2015, 10:32 AM
Name:	brake pards wear.png
Old 4th June 2015, 10:35 AM
That diagram is it. A single wire that runs from the instrument cluster through both the front brake pads and back to an earth.
Any wiring fault, nick, loose connection, rubbing, fault pad etc anywhere in the circuit, and the light comes on.
Its common to hardwire it to ground behind the instrument cluster to stop it false reporting if you have an issue other than worn pads...
Old 4th June 2015, 10:40 AM
David, I wouldn't describe mine as erratic, it's probably just a wire in one of the pads which is just exposed so only making contact when braking firmly.
So, reading that, both sides need to be worn as they are in series?
Any comment re MOT?
Old 4th June 2015, 06:12 PM
Any comment re MOT?
I've done a bit of rummaging around online and looked at the .gov web site MOT manual too.
It seems that pad wear warning lights are totally ignored by the MOT.
Obviously the brakes do still have to work, which they definitely do.
Old 11th August 2015, 03:47 PM
Gone for MOT today, driven there by my friendly neighbourhood MOT tester. He texted me to say the pads REALLY ARE worn.
(and no, it's not a fail, or anything at all)
The front discs need replacing, which I know, so it seems that their uneven surface has just cut through one of the pads at the wrong place.
Still a reasonable amount of pad left over much of the surface, but it will all get done fairly soon.
Old 11th August 2015, 04:19 PM
Apparently the nearside inside pads were the worst worn and they also have the wiring, so possibly a sticking caliper or piston?
Old 11th August 2015, 06:49 PM
If the wire is partially exposed, you won't get the warning come on until you use the brakes and wear away anything stopping the pad wear sensor touching the disc. Usually lasts a little while like that before the light stays on as soon as you apply the brakes to move the gear selector
Old 4th June 2015, 10:42 AM
Basically, the cluster is constantly monitoring pin 17. Normally it should always be grounded, like on the picture. If cluster senses that there is no ground (at least for a split of second) you will get a warning light until you switch off the ignition again.
The disc eats into a wire and eventually breaks the connection of the pin 17 to the ground.
Intermittent warning light with good break pads usually means oxidised contacts in the electrical connectors between the brake pads and harness of the car. See T4ad and T4ae on the picture.
Remove the wheel, trace the cable from brake pad into the car. Find the 2 pin connector, disconnect it (you will need a flat screwdriver to unlatch it) and inspect contacts within the connector. If you see green or white oxidation, then remove it. Also, make female side of connector tighter by squeezing contacts. You'll need a needle-shape tool for that. I used the dentist tool that you can buy on eBay for this. Before assembling the connector back please put some conserving non-conductive grease there to prevent future oxidation. You will never have the problem again.
Old 4th June 2015, 10:53 AM
OK, thanks, that makes more sense.
Given that it's ONLY applying the brakes that triggers the warning it suggests a poor contact close to the moving parts, i.e. the calipers, so first suspect is the local plug/wiring.
Old 4th June 2015, 02:46 PM
I started getting this warning just before setting off to the meet. If you or I are really unlucky a wire can break somewhere between the connectors and then its a real pain to find where it is broken underneath the insulation, or maybe if this is the case best to replace the whole wire. You can easily test which side with a continuity meter (pad side or car side when connector is unpluged).
I think someone on here has had to replace the car-side wire before.
