Old 20th June 2015, 11:18 AM
mannyo mannyo is offline
Have you looked at the rear diff?
sure it's not a diff whine?
The whine appears to be coming from a single corner and only noticeable from 60mph upwards. Below this speed the car is silent, driving round town you don't hear a thing. Only on A roads and motorways do you notice it, more so on the motorway because its quiet a bit louder. I've got used to it and blank it out now.
It sounds like a wheel bearing, I had the one on that side (supposedly) changed although the noise never completely went.
I changed the air filter today, with a lot of aggravation en-route.
After disconnecting the airbox from the intake pipework (for easy change) I discovered having undone 3 screws that screw number 4 of 5 was badly corroded and proving difficult to undo with a philips screwdriver. Had to use a flatblade to finally get that one undone. Screw number 5 (the one down by the radiator was completely dead.
Anyway got the old filter out, and put the new one in. Then struggled for the next 20 mins trying to get the airbox to seal properly, the new filter is a tight fit over the innards.
So a quick 20 minute job in total took more than 1hr. Still its done, lets see what if any difference a new filter makes.
Manny
Past
Old 21st June 2015, 12:03 PM
Turbo Tony's Avatar
Forgive my noob-ness, but what is the difference with the activated carbon filter?
Storytellers Villa Orlando
2008 Audi S8
Old 21st June 2015, 01:23 PM
Activated charcoal filter is supposed to reduce the smells entering the cabin, the charcoal absorbs some of the air contaminants I believe.
Manny
Past
Old 21st June 2015, 01:55 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
What he said.
Mannyo, I'm not sure how the quatto system or the would react but I wonder if you could get it up on a 2 post ramp with all 4 wheels off the ground and get it up to 60mph like that and see if you can hear it.
[center]
06 3.0TDI Quattro:
Options:
Old 21st June 2015, 02:34 PM
Turbo Tony's Avatar
OK. I'll keep an eye out for the activated charcoal filters. Thanks!
2008 Audi S8
Old 16th July 2015, 10:13 AM
Fingers crossed for mine, its booked in for its annual MOT tomorrow afternoon.
Manny
Past
Old 16th July 2015, 10:17 AM
Hope it sails through mate
Matt
Old 16th July 2015, 04:29 PM
Turbo Tony's Avatar
Good luck!
2008 Audi S8
Old 17th July 2015, 02:32 PM
She is in at the moment, should get the verdict later this afternoon.
Manny
Past
Old 17th July 2015, 03:00 PM
And its failed due to inoperative headlight washers.
The garage doing the MOT supposedly repaired them a few months ago, so they are looking at them again. I know they did work, but its been ages since I've driven at night and used the washers.
Manny
Past
