Old 14th February 2010, 06:18 PM
staffdog
Guest
Posts: n/a
Default Switched live
Hi All,
anyone know if there is a switched live in boot (Bose Amp maybe ??).
Also perm live under bonnet (easy to get at)
1996 4.2qs pf
Thanks Adrian
Old 15th February 2010, 01:26 PM
Switched live is definitely on the Bose amp as I've used that before....
Permanent live under the bonnet is more tricky. You would probably pick one up in the pleum chamber, or failing that you could wire through the plenum chamber to get access to the distribution board in the passenger footwell....
Old 16th February 2010, 09:39 PM
staffdog
Guest
Posts: n/a
Default RE:Sw Live in boot
Hi Ian,
thanks for your reply,dont suppose you can remember which pin/wire on Bose amp for sw live save me having to probe plug
regards Adrian
