#51
Thanks guys, especially Delboy for the thread.
I finally got there in the end after buying the remaining parts new from TPS. For me, there was no cheap chinese stick-on camera that worked. I had to buy the new boot handle strip light holder, Audi LVDS camera, and handle switch and gaskets. I painted it with rattle-cans and the job is 100% perfect after a 2000 grade gentle wet and dry and some mild cutting polish. I got the aerosols from a Movac bodyshop supplier for £19 for base coat and lacquer. This unusually hot weather really helped the finish I think. Last edited by snapdragon; 23rd April 2020 at 08:19 AM. |
#52
Your welcome, and good job man
Del ![]() |
#53
What a great thread, thanks Del!
If my new car doesn't have a reversing camera, I know not to panic. ...Now when are you planning on retrofitting ACC?!?! |
#54
Haha I have already bought the radar, just waiting till o get home before buying the last few bits so you will be sure to see a thread on it.
Del ![]() |
#55
Finally built my calibration device so have managed to get rid of the error. Given the resolution of the screen and thickness of the lines I don't think it's actually made any difference, but it's good to lose that persistent fault code
2004 A8 3.0 TDI Sport Brilliant Black - now gone |
#56
Well done SRG - Here is a PDF of the board someone kindly posted on a USA-based forum.
Sorry for not giving them a proper acknowledgement. I need to get this 'domino' printed out some time soon and have a go. The instructions are like krypton factor! Last edited by snapdragon; 23rd April 2020 at 08:19 AM. |
#57
This was the one I used which had dimensions on it. I was orihpginally planning on printing it on one of the plotters at work, but didn't fancy having to explain where all the ink went, so used fablon instead and some chipboard.
The more observant may notice the bits of paper stuck round the edges as the chipboard wasn't quite wide enough ![]()
#58
That's great thanks. I'll probably make one then, but need to wait for the securing clamp that holds the camera into it's aperture. Audi don't have, even in Germany any
#59
Nice, did you do the calibration using vcds or vas?
Del ![]() |
#60
I used VCDS and followed the guide from the Ross Tech wiki, adjusting the wheelbase distance as the wiki is for a Q7 rather than the A8.
I would have preferred to use the VAS, as it is much simpler, but had lent mine to a friend
