Old 8th July 2015, 09:52 PM
Sorry to drag up an old thread, but this is exactly what seems to be happening to mine. Discs warped, a new set of Brembo discs with Pagid pads fitted and bad warping again after taking it easy for a couple of hundred miles.
Should I look into the callipers and pins? I often hear a clicks or clattering of what I suspect are the pins when manoeuvring and braking while parking
I would get the callipers checked, sounds like you might have a sticky/stuck piston
