Old 9th July 2015, 07:19 PM
Originally Posted by V8man View Post
Looks like they will try replacing ABS pump to rectify the problem. They asked me to source one. So when they text me the part number tomorrow I'll be straight on to out sponsors/hosts to acquire one. I did broach the subject of how much all this is gonna cost me. He did say he won't charge me for all the labour thus far. Lets hope this sorts the original issue which I've forgotten as its changed so many times.
Just want my car back. All this walking to the station in summery weather is far too healthy
If you replace the abs pump you must replace both the pump and the abs ECU which is bolted to it. You need to source one with the same codes as you already have on your current one and then change the whole unit and bleed the brakes afterwards. From memory there are about 3 or 4 combinations of codes and so make sure you have that information from the sticker on the ECU and the stamp on the side of the abs block before you hunt for one or call our sponsors
Has the abs unit thrown up any fault codes though ??
