Old 6th August 2015, 09:01 PM
Yeah pity that , a few pictures tells a thousand words and all that .... would anyone know if I get headrests with the screens in Would the headrest electric up and down function still work , I'm not sure how they do the motor function
Old 6th August 2015, 09:02 PM
Yes there must be a way as my car has aftermarket screens fitted and they still go up and down electrically
Old 7th August 2015, 07:53 PM
Mutley has not monitored this forum since April 2013.
I guess this means that he is no longer interested, great shame.
Does anyone have a contact number or address for him?
The photos would be a great help.
Old 8th August 2015, 12:45 PM
What make are the ones you have delboy ,what size screens and so on , the 9 inch screens ones say the headrest total width is 300 mm .....will they look a bit bulky do you think ??
could you post some pictures up if you get time so i get an idea how it all looks in the car .
Many thanks Lee
Old 8th August 2015, 02:43 PM
I found these pictures, if they are of use, in Google cache.
ID:	11551   Click image for larger version
ID:	11552   Click image for larger version
ID:	11553   Click image for larger version
ID:	11554   Click image for larger version
ID:	11555   Click image for larger version
Matt
Old 8th August 2015, 04:58 PM
Thanks Matt,
They do give a better idea of what is involved.
One of the photos show a wire coming out the bottom of the support column. One of the sellers did write that his cables had small connectors that would fit through the supports.
Old 12th August 2015, 04:37 PM
Default Sorry for the delay
Here you go
Old 13th August 2015, 07:01 PM
Thanks Matt,
its unlikely if they are like mine, the two supports are in fact one U shaped piece in a loop, i did see one done where they had cut a corner of off the u shape (not sure if its mutleys) and fed wires down, but i dont think they are wide enough for anything but a cable and i decided that the most important thing was the safety , cutting in must have weakened them i opted to let the wire just go down beside the strut
