Have you had a look in the basic settings to see what your current angles are?
Although VCDS is vague, it does clearly show two boxes with angles in them, mine was showing 2.xxx on one and 0.1xx on the other I suspect the 2 degree one is vertical alignment because the car seems to sit close to the car in front. I done basic settings on both and tweaked the sensor up by a bit and will see how I get on. According to Elsa on the matter the radar should be with in 0.5 degrees to run happily so thats my mission. I will keep you updated as I go and hopefully figure out whats what to write a label file to make it easier in future.
Del ![]() Last edited by Delboy; 13th August 2015 at 05:51 PM. |
