Are the rear wheels ajustable? I used to track cars in ATS although that was 15 years ago, there 4 wheel alinement then was 2 gauges that hook over the rear wheels and the front parts have the light in them. It was not allways possible to get the reading between the 2 front wheels and then line the rears to suit, because the adjustment is on the track end. The tolerances are sometimes + or - 3mm (dependant on make). So it was then possible to line the front wheel to the rears and be within tolerance for the toe in / out on front wheels.
All the laser has done is replace the light bulb that would project a line onto the gauges. I would use someone reliable but would be reluctant to pay anymore than £50 unless they are able to ajust the rears, fronts and camber (if it's ajustable). Just because it's an A8 dosen't mean it's anymore of a job to track than anything else like a Land Rover or Impretza and therefore shouldn't cost anymore. |
according to the website........instead of using a light on a guage attached to the rear wheel (tracking) the laser is alignment that uses the centre line of the car and measures 12 angles (3 per wheel?) and make allowances for rim runout then sets the wheels alignment independantly on each axle so no wheels are set up using other wheels as the base line inviting problems. I honestly didn't realise the was a difference between tracking and alignment but it appears thats where the price difference comes from! All i know is when i had a previous car tracked that should have been aligned it handled like bambi on beer, when i had laser alignment done it was like a new one. I know what i'd pay for.........
Now that is clever, just goes to show how far behind I am.
3 angles per wheel could be right too Camber, Toe and caster maybe. That’ll be what you pay for then. I’ll shut up now. |
in fairness the RS6 was in a mess, hence the cost.
It had had KW adjustables fitted in place of the DRC, which is good, but they had literally never been 'adjusted' The problem with adjustables is that you can alter the height, damping etc and unless you get it consistent across all 4 corners, it will handle like a bag o' nails, which the RS6 did. The nose was notably higher in the air than it should be also. So, they alligned the wheels, suspension, ride height etc, all laser driven with computer print outs, but the proof was in the ride home - OMG - It was a different car. Interestingly, the RS6 (and many Audis no doubt) dont have much adjustment on the front suspension, so they undid the front subframe and shuffled it about relitive to the chassis to get things in line, seems quite sensible when you think about it, but specialist stuff, you wont get it for cheap money....
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
Undoing the sub frame is definitely a way of centring it all up for sure and like you say not for the numptys to do. I know that Audi Track rod ends seize up for a pass time mostly to do with the position of them I think being right behind the wheel where all the wet and **** goes off the tyre.
So is the rear adjustable on a standard 8’s suspension Ian? |
Just so your all aware before you take you 8s in for alignment.
On the front you can only adjust toe and centre camber. No caster adjustments can be made independently. Although the method of centring camber is by loosening the subframe bolts and levering the subframe left or right. When doing this it can also be moved slightly forward or backward and twisted which will throw out castor and camber. So get someone who knows what they are doing. On the rear you can adjust toe and camber.
Thats totally what I was just going to say, but Mike beat me to it ![]()
Thanks for clearing that up men.
Mine will stay as is, although it would look good with negative camber on the rear. I’m surprised none of you guys track daying your cars have tried it. Are the S8 control arms longer than the standard 8’s to allow for the lower suspension or is it not enough to make a difference to the camber. Here's a Golf with plenty too much Last edited by Dezzy; 24th February 2010 at 05:18 PM. |
Do you need to get the four wheel alignment done after changing your tyres?
No, tyres should make no difference to the track of the car. Driving into kerbs will and some of these pot holes, i thought i lost a wheel the other night.
