Old 22nd August 2015, 08:19 PM
Phil303 Phil303 is offline
Default Key Fob Window Opening and Closing
Some work carried out by my garage had some codes cleared from the ECU.
What also appears to have been cleared is the function that let me open and close the windows and sunroof by holding down the Unlock button on the key fob.
Is it possible to active this again with delving into VAG-COM and all that (in the same way a few button press sequences make the drivers window open with a single touch rather than having to hold the window down button continually)?
Old 22nd August 2015, 09:17 PM
B@fink B@fink is offline
If they had the battery off the windows will need to relearn the full up/down before they one touch again. I think you just need to push the button until it's fully lowered and then again until it's fully raised (for each window) and the one touch feature works again. I don't know about the full open option off the fob though. See if once the one touch is working the other part starts working some things are linked without being obviously so. If the air mass meter is iffy for example the tiptronic doesn't work.
Old 22nd August 2015, 09:23 PM
This is the central locking codes and window open / close guidance i have used. It requires VCDS (VAGCOM) of course. Hope it helps.
Old 22nd August 2015, 09:31 PM
The one-touch window works okay.
Thanks for the code list, that's perfect. Now to pester AndyCaCa and his VCDS gubbins.
Hey Andy....
Old 23rd August 2015, 08:31 AM
andycaca andycaca is offline
2001 S8 D2
