Some work carried out by my garage had some codes cleared from the ECU.
What also appears to have been cleared is the function that let me open and close the windows and sunroof by holding down the Unlock button on the key fob. Is it possible to active this again with delving into VAG-COM and all that (in the same way a few button press sequences make the drivers window open with a single touch rather than having to hold the window down button continually)? |
If they had the battery off the windows will need to relearn the full up/down before they one touch again. I think you just need to push the button until it's fully lowered and then again until it's fully raised (for each window) and the one touch feature works again. I don't know about the full open option off the fob though. See if once the one touch is working the other part starts working some things are linked without being obviously so. If the air mass meter is iffy for example the tiptronic doesn't work.
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound. ![]() Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting. Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids ![]() Last edited by B@fink; 22nd August 2015 at 09:25 PM. |
This is the central locking codes and window open / close guidance i have used. It requires VCDS (VAGCOM) of course. Hope it helps.
The one-touch window works okay.
Thanks for the code list, that's perfect. Now to pester AndyCaCa and his VCDS gubbins. Hey Andy.... |
2001 S8 D2 ![]() |
