Hello all
The rear of my glass sunroof is sitting low - ie not flush with the roof - any idea if it can be adjusted to fit properly flush It opens and closes ok - but have had a small leak and this and blocked drains may not have helped, so hope there is away to make it fit better! Thanks Mark |
Yes it can. I'll dig out the reference which is in the Tech Dump.
Its in the Manual on General Body Assembly Exterior page 125.
Thanks for that
Mark |
But it's a 2 man job isn't it David?
One inside, one outside to check level??
Exactly. The requirement to have the leading edge ~0-1mm below and the trailing edge ~0-1mm above the roof level requires the outside person to hold the sunroof in place /check the levels as the person inside tightens the screws.
Thanks for that, will give it a go - just have to fathom hoe to get the headliner off the sunroof to expose the bolts
Open the sunroof about half way. Pop the 2 plastic clips at the front and then push the headlining backwards.
great, thanks
