Old 8th December 2014, 07:39 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Output test on VCDS?
[center]
06 3.0TDI Quattro:
Options:
Old 8th December 2014, 02:11 PM
mikes2 mikes2 is offline
if the water level is too low, the headlamp washer pump will not run
2002 3.7 quattro sport (SOLD)
Old 19th December 2014, 10:17 AM
Had the car in yesterday for a few bits (the throttle position sensor was on back order, so they couldn't do that), but the headlight washer problem was a couple of corroded electrical connections to the pump motor. Now that's a good result just before Xmas!
Old 19th December 2014, 06:54 PM
Same as mine was then - that's £100+ saved then lol
